20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Lifting up building for curb
Happy New Year all. I have recently been informed AFTER I got the model in shape to begin CD's that we need to put a 6" concrete curb around the entire perimeter of the building. My options are to A) offset all walls and put in concrete wall and align it. B) create a stacked wall with 6" curb. C) add the curb to bldg & wall sections and detail callouts. I am leaning towards C as adding the curb would be important if we were doing material quantities, but this is our first project. But if I WERE to elect option A (I hate stacked walls) what would be the best way in your opinion? RAC 2008 - Thanks!
----------------------------------- Revit Architecture 2010 |
Are you actually raising the building pad up 6" or just putting the walls on a 6" curb? If it was my job I would actually add the curb (I hate stacked walls to) as a seperate wall, attach the top of the curb wall as well as the base of the stud wall to a refernce plane then everything should flex accordingly. If you dont add the curb you risk not showing it in a section or someone missing it last minuet. If you do it as mentioned above all you have to do is adjust the refence plane if you need to go to a 4" or 6" curb. You could accomplish this by copy/ paste align into a new project, change the wall types and height and then drop back into your project if you have a ton of walls.... HTH Nick
Thanks Nick. yes, there will be a 6" curb around the perimeter of the building and "wet areas" such as restrooms. The walls will sit on top of those. It's a one-story 7000 sq ft footprint. I can easily select all the perimeter walls and do a base offset from the ground floor of 6". then draw a curb all the way around at slab edges. I have to break the curb at doors unless I want to use stack walls - which i dont. Then I can lock down the pad, curb, wall all to the grid. Since it's a small building and our first time at this, I should model as much simple stuff that I can. Thanks again for your help.
Lifting a existing building |
Mon, May 12, 2014 at 10:00:38 AM
Creating curb that conforms to a topography |
Sat, Jun 2, 2012 at 9:15:31 AM
13
How do I make curb |
Wed, Dec 14, 2011 at 3:57:42 PM
How to do a road curb that follow a sloped roadway? |
Mon, Aug 12, 2013 at 1:34:06 AM
how to add elevation to curb sweeps? |
Fri, Feb 4, 2011 at 3:54:40 PM
