9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Wall sweeps - trims
4 Posts No Rating |
Does anyone know of a way to get vertical trims to turn the corner at wall intersections? I'm having a problem getting vertical trim to align with the edge of the wall on both sides of the intersection.
Could you attach an image so I understand what you mean by vertical trim? Is vertical trim located at a corner?
4 Posts No Rating |
See attached. I'm trying to wrap the corner of this bay with Hardi trim. I'm using a vertical wall sweep to create the trim, but I can only place the trim at one side of the corner. The closest I can get to the corner on the other wall face is the thickness of the wall it is intersecting.
I have solved this problem by creating an in place extrusion in plan view. It would be nice if the developers would create an easy tool for trim like this.
I recommend you make a generic model family for your corner trim, much easier than 2 vert. sweeps.
4 Posts No Rating |
thanks to all who responded. . . I think I'll try the generic model family.
Ceilings: soffit with sweeps |
Sun, Nov 4, 2007 at 2:23:12 PM
Angling Wall Sweeps |
How do you model complicated exterior masonry trims around building entries? |
Fri, Jul 15, 2011 at 4:01:23 AM
Walls with automatic wall sweeps |
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Wall Sweeps |
Wed, Feb 29, 2012 at 9:39:46 AM
