Forums >> Revit Building >> Technical Support >> Material Legend or Finish Legend
Thu, Dec 27, 2007 at 9:46:28 AM | Material Legend or Finish Legend
gregs
1 Stars: 1 Votes
Hello All,
I am new to the forums and have a question on RAC 2008.We are working on an interior project and have the room and door schedules all completed in REVIT, but I was wondering how do you do the Finish Legend;
(PNT-01= Benjamin Moore Cool Blue #123, Satin finish, Gypusm Finish Level 4) that sort of thing
This would cover floors, walls, base, ceilings, and anything else I can think of.
I was hoping there was some way to create this list and then select from my room schedule pulldowns (so only floor materials could be selected).
Can REVIT do this or do I need to complete this offline in some other program ?
Thanks,Greg
Thu, Dec 27, 2007 at 10:00:03 AM | Material Legend or Finish Legend
You can add the finish field to your room or door schedule.  Once you have entered the data you have shown, it will show up in the pull down for other rooms.
Thu, Dec 27, 2007 at 10:13:05 AM | Material Legend or Finish Legend
gregs
1 Stars: 1 Votes
Thanks for the info. But I was not clear enough in my post. I know whatever I type into the Schedule will show up in the pickbox, but that is not what I trying to do. We usually create a stand alone Finish Schedule and then create the Room Schedule. So I am trying to find a way to create the Legend first. I just found a simliar thread about this and the suggestion was to just create a drafting view with text and lines, maybe that is the best I can do.
Thanks,Greg
Mon, Dec 31, 2007 at 7:34:59 AM | Material Legend or Finish Legend
? ? ?   Still don't understand what you are saying.
Do you want columns for your finishes with X boxes?  If so, you can do that using a yes/no variable for each column.
Mon, Dec 31, 2007 at 8:23:23 AM | Material Legend or Finish Legend
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
gregs,
If i understand the question you want to build a legend of all your finishes before you fill them out in the schedule. If so this is going to be difficult. Keep in mind that the schedule is getting its information directly from the model. Unless you have already defined the Materials and finishes in your objects, the schedule won't show any information. If you if you are just wanting a seperate finish legend for the project you can create a Multi-category Material Takeoff. This will list all materials used in the project. Once again this will only show the materials that are assigned to the objects in the model. I hope I haven't rambled to much here. Let us know if you figure it out.
Mon, Apr 7, 2008 at 12:01:55 PM | Material Legend or Finish Legend
cnncasey
1 Stars: 1 Votes
I have found the answer to this. We were having a similar problem. If you still need to know how to create this Material Schedule...NOT A ROOM SCHEDULE. Let me know and I will send the instructions. It involves creating a family and a Note Block, it is something that works just like a schedule. it is a bit lentghty but very easy to folow. Once the family is creating with all it's parameters it's as smooth as butter from there on out to create these schedules in future projects.
Mon, Apr 7, 2008 at 12:40:59 PM | Material Legend or Finish Legend
Bm3875
Bm3875 Avatar
4 Stars: 7 Votes
Interesting...can you post a PDF or something along those lines?
Brandon Pike | Owner/BIM Specialist
cad.web.print
website: http://www.thinkdesign-studios.com
blog: http://www.bimtionary.blogspot.com/
Wed, Oct 22, 2008 at 9:23:29 AM | Material Legend or Finish Legend
aking05
I need help with this!
I have created a room schedule that notes all the finishes in the individual rooms.  I now need to create a material schedule that identifies the type of paint, floor, etc selections.
Wed, Oct 22, 2008 at 10:50:02 AM | Material Legend or Finish Legend
aking05
To clarify I am trying to figure out how to create a finish schedule as the attached pdf indicates. I have already created a room schedule (attached).  Please help!
Mon, Aug 10, 2009 at 10:50:59 AM | Material Legend or Finish Legend
BDerrick
3.5 Stars: 3 Votes
any success with this? How to link a Finish Legend with a Room Finish Schedule.  The attached PDFs show the information I want to include in my project but I can't get them linked.
Wed, Apr 20, 2011 at 8:34:19 AM | Material Legend or Finish Legend
eme00
Hi,
I was wondering if anyone figured out how to do this...we're very interested in linking our material schedule & finish schedule in this manner....what happened?  Smile
-E
Revit Architecture 2012 x64
Wed, Apr 20, 2011 at 11:02:38 AM | Material Legend or Finish Legend
eme00
Hi,
-E
Wed, Apr 20, 2011 at 12:00:30 PM | Material Legend or Finish Legend
#13
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
We use a room schedule key for this with custom PROJECT shared parameters...type in what you want, add the key to the schedule and tell it what to be.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, Oct 13, 2020 at 1:29:13 PM | cnncasey
#14
hanbyjm
Quoting cnncasey from 2008-04-07 12:01:55
"I have found the answer to this. We were having a similar problem. If you still need to know how to create this Material Schedule...NOT A ROOM SCHEDULE. Let me know and I will send the instructions. It involves creating a family and a Note Block, it is something that works just like a schedule. it is a bit lentghty but very easy to folow. Once the family is creating with all it's parameters it's as smooth as butter from there on out to create these schedules in future projects."
If you are still on here, I would like the instructions.
Floor Legend
Thu, Nov 2, 2006 at 10:35:07 AM
Hiding Legend Notation
Tue, Jun 25, 2013 at 10:25:19 AM
VIEWING LEGEND COMPONENTS PROPERLY
Tue, Apr 14, 2009 at 10:04:02 AM
Legend View Range
Mon, Jan 27, 2014 at 8:46:21 AM
Revit 2016 Room finish schedule and material schedule
Thu, Mar 9, 2017 at 3:41:41 PM
Page generation time: 0.2923
