15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Can't get sweep brick to read the same as wall brick in coarse sections?
I have brick set to be solid black fill at "coarse" detail. I use this on building sections where walls are small enough that I just need them black, not detailed. I have brick sweeps that do not respond to the material designation in coarse detail. They retain the angled lines which, at the building section scales, are very widely spaced while the rest of the wall is black filled. Looks really dumb and amateurish. At one time, when you could talk to Revit Help Architects on the phone, I was told they knew about this problem and were working on it. Well, in RAC 2008, it still ain't fixed. Anyone know a way around this problem?
So you want a solid black brick sweep, correct?
I simply would like the brick material to be controlled the same in the sweeps as it is in the wall. The setting of the material to read as solid fill in coarse detail works when it is in the wall but doesn't work when the exact same material is used in a sweep.
Show brick veneer in coarse view |
Fri, Aug 1, 2008 at 11:38:05 AM
Existing 12" wall w/4" brick-4" cavity-4" brick. Can't get plan brick to s |
Wed, Apr 8, 2009 at 5:08:39 PM
Hello Newbie here, brick on brick on cmu wall type doesn't show up |
Thu, Jan 27, 2011 at 1:06:15 PM
Brick wall sweep surface pattern??? |
Wed, Sep 14, 2011 at 9:07:27 PM
brick sill below window on brick wall |
Thu, Mar 13, 2008 at 6:10:23 PM
