Forums >> Revit Systems >> Technical Support >> How thumbnail view is created in revit
Wed, Dec 26, 2007 at 10:56:44 PM | How thumbnail view is created in revit
sidman
When I save family for an example lighting fixture ceiling based, the 3D view created shows top of the ceiling while utwhile I saw in one of the family the view saves as thumbnail do not show ceiling. I have attached the file where thumbnail view is created. Can you pleae help me how to do it.I know model lines can be seen in and on a 3D surface but why do we need to draft them.
Thu, Dec 27, 2007 at 9:02:42 AM | How thumbnail view is created in revit
UserError
UserError Avatar
3 Stars: 1 Votes
answer to first question: ceilings were turned off in your 3d view. if you want to see them in the thumbnail view, they should be turned on.
I don't understand what you are asking in the second question. why draft model lines? could you explain a little more?
Tue, Jan 8, 2008 at 6:59:17 AM | How thumbnail view is created in revit
sidman
I have seen in some families that model lines are drawn in plan. What is the need of drawing model lines when we can view the object in plan
Tue, Jan 8, 2008 at 7:15:10 AM | sidman
UserError
UserError Avatar
3 Stars: 1 Votes
Quoting sidman from 2008-01-08 06:59:17
"What is the need of drawing model lines when we can view the object in plan"
I agree. Guess it doesn't hurt though unless you for certain don't need to see something in 3d, such like a door swing.
Tue, Jan 8, 2008 at 7:23:19 AM | How thumbnail view is created in revit
sidman
Thank you for your reply
Setting Family thumbnail orientation in PROJECT (After loading the Family).
Wed, Aug 8, 2018 at 11:05:44 AM
Can't see preview of Families in Thumbnail view.
Mon, Oct 5, 2009 at 10:21:40 PM
revit on vista shows only incon and no thumbnail
Mon, Jan 25, 2010 at 12:04:01 PM
Any way of changing default view of a family thumbnail?
Thu, Nov 7, 2013 at 8:07:04 AM
Thumbnail preview for NESTED Revit Families
Tue, May 14, 2013 at 5:18:20 AM
Page generation time: 2.4308
