Forums >> Revit Building >> Technical Support >> rotating materials
Wed, Dec 26, 2007 at 6:28:25 AM | rotating materials
ileso
hi im new at this,
ive been trying to rotate materials in the renders. like stone pavings etc. but i cant find the controls for this.
can some one help me?, like for floors, where i might have wood flooring and would lioke to orientate the flooring with the room...
Wed, Dec 26, 2007 at 7:24:31 AM | rotating materials
latemore
latemore Avatar
3 Stars: 2 Votes
i have found if you have 'lines' that need to be horizontal or vertical, then you'll need two materials with those options, but and this is the weird bit, if you have any other need for angled lines, you can use the align tool to orientate the lines to anything that is not vertical or horizontal.  a bit like the way you can align any surface pattern with anything.  try the align tool and see what happens - it is probably the most useful tool in revit!
Wed, Dec 26, 2007 at 7:31:44 AM | rotating materials
ileso
does this work for rendering materials? i mean, if i align the lines to the orientation i want does the material itself align as well in the final render?
Wed, Dec 26, 2007 at 9:30:15 AM | rotating materials
The tie into AccuRENDER seems to be a little weak in regards to how you manage 3d bitmaps.  15 years ago when I used AccuRENDER with AutoCAD, I remember that I could set the direction of the bitmap for each surface but I'm not sure how you do that now.
For shaded with edges, you should be using model category fill patterns that you can adjustthe orientation of.  For the rendered items, you will have to create a material for each orientation.  You can then edit the bitmap of the material and rotate it to suit your needs.  The process seems to be more complicated then I remember it.
Wed, Dec 26, 2007 at 10:45:40 AM | rotating materials
ileso
autodesk hasent done its homework, this way isnt very viable when you have your boss leaning over your shoulder and asking you to quickly rotate a tecture in acordance with your acad plans.... well, will work at it
thanks anyway, i thought there should be an easy way to do this.
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating mullions
Thu, Jul 24, 2008 at 4:27:53 PM
Rotating Views On a Sheet [ 1 2 ]
Tue, Jun 17, 2008 at 12:49:46 AM
18
Rotate Floor Plan without rotating project
Mon, Nov 4, 2013 at 1:14:56 PM
Rotating Viewports without rotating title
Wed, Apr 22, 2009 at 10:52:58 PM
Page generation time: 0.1743
