Forums >> Revit Structure >> Tips & Tricks >> Sloping Slabs
Fri, Dec 21, 2007 at 11:03:23 AM | Sloping Slabs
luisrpv
I am trying to figure out how I can and slope points to a slab that has a curve. It works fine when its a simple shape but once I introduce a curve then I no longer have the option to set points. Any suggestions?
Wed, Jan 16, 2008 at 1:42:15 PM | Sloping Slabs
hhwse
I ran into the same thing on a recent project.  You need to make a segmented line to represent the curve.  I placed the segmented line inside the wall and joined geometry.  It’s not perfect but it works.
Tue, Dec 23, 2008 at 5:51:39 PM | luisrpv
unforgivable
Quoting luisrpv from 2007-12-21 11:03:23
"I am trying to figure out how I can and slope points to a slab that has a curve. It works fine when its a simple shape but once I introduce a curve then I no longer have the option to set points. Any suggestions?"
Why don't you try using mass! It's great way to make somthing if you can't thing any other way,
http://tutorials-revit.blogspot.com/
Tue, Dec 23, 2008 at 7:37:45 PM | Sloping Slabs
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I'm guessing that you are trying to modify sub elements on a curved slab to set elevation points.
As you found it doesn't work. You can't use the sub elements option on a curved slab.
What I do is the slab so it has no curves, angles don't matter, just no curves.
Then I modify the points I need and create a GENERIC MODEL > VOID to cut out the geometry that needs to be curved.
HTH
 p.s. you have to use a generic model as you can't have a void mass.
-Brett
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Mon, Jan 5, 2009 at 4:41:00 AM | Sloping Slabs
chuaheyia
chuaheyia Avatar
3 Stars: 2 Votes
yep, creat a customized slab with massing.
Sun, Jan 18, 2009 at 12:01:27 AM | Sloping Slabs
mgr2820
2 Stars: 2 Votes
You dont need to create a void family to reprofile your slab. Use Model>Opening>Opening by Face. This works for roofs and area drains as well.
Sun, Jan 18, 2009 at 2:46:13 PM | Sloping Slabs
brettgoodchild
4 Stars: 17 Votes
This works fine uless the roof has multiple faces. I really don't want to manage multiple openings if I don't have to.
                             ~ Abraham Lincoln
Thu, Jan 22, 2009 at 5:45:01 AM | Sloping Slabs
Adnanito
3 Stars: 2 Votes
Previously this modifier couldn't be applied to any floor or roof that has a nonstraight segment. But in the new version of revit "Revit 2009" you can apply the modifier to curved floor/roof.However, you can work around that (If  you r using Revit 2008 or older version) by using a vertical opening (Like the Figure provided). You need to start with a simplified straight segment floor/roof shape that contains no arcs. You add the arc as a subtraction in the form of an opening. By using the Opening tool in the Modeling tab and choosing the Vertical option, you can then sketch the arcs you need.
Moh_Adnan_Alj
Thickened Slab Edge on Sloping Slabs
Thu, Apr 16, 2009 at 3:39:08 PM
Sloped Slabs
Sat, May 26, 2007 at 1:41:18 AM
11
recesses in slabs
Thu, Sep 29, 2005 at 3:33:42 AM
Floor slabs showing dashed instead of Solid
Wed, Jun 5, 2013 at 5:53:00 PM
12
Urgent Help ! Sloping Floors
Wed, May 4, 2011 at 4:04:04 AM
Page generation time: 0.0450
