Forums >> Revit Building >> Technical Support >> Revisions in Drawing List
Fri, Dec 21, 2007 at 10:51:14 AM | Revisions in Drawing List
SkamikazeKO
I am trying to create a parameter that will put an "X" in my drawing list if a sheet was associated with a revision.  I have a revision schedule built into my titleblock.  The drawing list would have a column for each revision or submission of the set and if a sheet was issued or revised, there would be an x in that column.  Does anyone know what I would have to do to achieve this?  I am using Revit Architecture 2008.  Thanks.
Thu, Dec 18, 2008 at 12:41:04 PM | Revisions in Drawing List
arlettemp
Any luck yet?  I have been trying to figure this out for several days and have had no luck!  Help!!!
Tue, Mar 6, 2012 at 1:05:53 PM | Revisions in Drawing List
saleeby
saleeby Avatar
Has anyone ever found a solution to this problem?
Revit Architecture 2012
Tue, Mar 6, 2012 at 1:34:00 PM | Revisions in Drawing List
TKennedy
4 Stars: 8 Votes
I have not found an automated way of doing this (i.e. reading the rev schedule and filling out the drawing list), but it can be done. You will need a Yes/No parameter for each revision (doesn't need to be named anything special, 'Issue 1' is fine). Add this parameter to your schedule, and make it a hidden column. Add a Calculated Value to your schedule. Again, naming isn't important here, you can change the heading to read how you like. The formula should be *if(Issue 1, "X", "")*. If Issue 1 is checked (the parameter will show up in the instance properties of the sheets), it will place an 'X' in the cell.
If you have more than a few sheets/issues, I would create a duplicate schedule to work in with the Yes/No parameter columns visible.
Tue, Mar 6, 2012 at 1:35:01 PM | Revisions in Drawing List
We have a revised sheet index in our project.  See attached.
Tue, Mar 6, 2012 at 1:39:53 PM | Revisions in Drawing List
LIZARD2806
3.5 Stars: 7 Votes
1. From the schedule edit dialog box, add the field for "Current Revision Issued". (this will be a hidden column)
2. Add a Calculated Value named "REVISED" (Or whatever you want it to say in your schedule).  Make it a type Text, nad in the Forumla box type:  if (Current Revision Issued, "X", "").
3.  Say OK and close out of edit box.
4.  Right click on Current Revision Issued header and click hide column.
Now, as long as the current revision is issued, it will have an X.  You may have to play with this a bit if you go through a lot of revisions and reissues, but it shoul dat least get you started.  HTH.
EDIT....Sorry, I misread the question and this doesn't answer it......I'll leave it here in case it helps someone else.
Edited on: Tue, Mar 6, 2012 at 1:41:17 PM
Edited on: Tue, Mar 6, 2012 at 1:43:01 PM
Tue, Mar 6, 2012 at 1:49:47 PM | Revisions in Drawing List
TKennedy
4 Stars: 8 Votes
WWHub, how do you get that setup to work when you have non-numeric revisions?
Tue, Mar 6, 2012 at 1:53:10 PM | Revisions in Drawing List
TKennedy - I do not understand your question.  My schedule works the same letters or numbers.
Tue, Mar 6, 2012 at 2:13:47 PM | Revisions in Drawing List
saleeby
saleeby Avatar
Thanks TK,
I got the yes/no parameter on there and I was trying to figure out how to replace the yes or no with symbols.
What you are describing with the hidden column and calculated value should work great.
WWH, I found the current revision parameters and I think they work great because they are smart,
but my firm is used to their standards and I'm trying not to make too many waves as I push for "The Big Switch."
Also, what is the status parameter you are using?
Thanks again for the help.
Tue, Mar 6, 2012 at 2:34:41 PM | Revisions in Drawing List
The status parameter is an in-house control value.
Tue, Mar 6, 2012 at 2:37:26 PM | Revisions in Drawing List
TKennedy
4 Stars: 8 Votes
WWHub, I misphrased that, I mean numbering is set to none. When I do that, all of the revision columns are blank, it only fills them out when numbering is set to numeric or alphabetic.
The other problem I have with using the revision parameters like that is it only shows the current revision for a sheet, and I (and apparently other folks) need a list showing all issues/revisions.
Tracking Revisions thru the Drawing Schedule
Thu, Sep 13, 2007 at 3:08:42 AM
Drawing List and Revisions
Thu, Sep 13, 2007 at 4:17:01 AM
Sheet list showing previous revisions...
Tue, Nov 15, 2011 at 2:18:28 PM
Revit Drawing List
Tue, Mar 15, 2011 at 5:20:07 PM
Drawing List's
Wed, May 26, 2010 at 11:49:42 AM
Page generation time: 0.9196
