Forums >> Revit Building >> Technical Support >> Hotkey for closing current window only?
Thu, Dec 20, 2007 at 5:30:21 PM | Hotkey for closing current window only?
Robb
Is there a hotkey to close the current/active view? In any othe rprogram I usually use the windows hotkey ctrl+w but that does not seem to work in Revit. Is there another method or hotkey instead of having to mouse over to the "X" to close?
TIA!
Primary: Revit Architecture 2008\AutoCAD 2007Old Versions: Revit 9.1\AutoCAD 2002
Thu, Dec 20, 2007 at 5:38:07 PM | Hotkey for closing current window only?
Debo
Try Ctrl & Tab
Thu, Dec 20, 2007 at 6:09:37 PM | Hotkey for closing current window only?
Robb
ctrl+tab toggles between views but does not close it. I like to keep the amount of views I have open to a minimum. I am always opening/closing views keeping only the ones I need opened. It would be really convenient to have a hotkey that does it or to have the ctrl+w feature back... maybe Revit has it assigned to something else (I havent figured it out yet).. For me it makes a huge difference in maneuvering through my project. Thanks again.
Thu, Dec 20, 2007 at 8:13:11 PM | Hotkey for closing current window only?
Tmifsud
Try CTRL+F4
Troy - myCADD
Fri, Dec 21, 2007 at 4:12:23 PM | Hotkey for closing current window only?
Robb
ctrl+f4 works. I am used to alt+f4 as closing the entire program. ctrl+f4 feels a little awkward but that will do. Thanks!
An Error Occurred, Window Closing... project goes solid black randomly on zoom
Thu, Dec 13, 2012 at 11:40:09 PM
Why can't I make an "accelerator" so that space bar repeats last command?
Mon, Jan 7, 2008 at 5:39:07 PM
Revit 2017 shuts when either opening, saving or closing a window.
Mon, Mar 6, 2017 at 10:24:44 AM
Revit 2012 crashes after closing Material Editor
Sun, Dec 11, 2011 at 2:27:16 PM
Closing Down a Project
Thu, Mar 13, 2008 at 2:51:53 PM
Page generation time: 0.2022
