Forums >> Revit Building >> Technical Support >> Door & HM frame w/ 4" head
Wed, Dec 19, 2007 at 5:34:13 PM | Door & HM frame w/ 4" head
trhymans
I am fairly new and am having trouble w/ a door and frame family.  I have a good door and HM frame family that lets me change the frame face dimension but it changes the jams and the head.  I need a door & frame that has a 4" head and 2" jambs.  The family uses a sweep for the head and jambs and I haven't been able to figure out how to make the head 4".  Anyone out there have a door and frame family like this???
Thu, Dec 20, 2007 at 7:45:06 AM | Door & HM frame w/ 4" head
You could modify the family in several ways. One would be to add a seperate sweep at the head thats adds the extra 2 inches.  .... good learning experience.
Thu, Dec 20, 2007 at 8:17:28 AM | Door & HM frame w/ 4" head
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
WWHub's idea is better than mine, so I'll just add that if you do the extra 2" as a sweep be sure you Join Geometry of the two sweeps to eliminate the extra line at the seam.
Thu, Dec 20, 2007 at 5:37:46 PM | Door & HM frame w/ 4" head
trhymans
I cheated a little and just created a solid extrusion for the additional 2" at the head and it works great.  I did the join geometry and no lines.  Thanks for the idea.
Fri, Dec 21, 2007 at 7:05:40 AM | Door & HM frame w/ 4" head
sdbrown
5 Stars: 3 Votes
Here is my family that does that. I just created the extrusion in elevation so it could have diff. sizes for head and jamb.
Hollow Metal Door Frame
Thu, Nov 1, 2007 at 3:09:02 PM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame
Thu, May 6, 2010 at 7:29:41 AM
flip control only door panel & not frame/trim revit 2015
Mon, Apr 27, 2015 at 10:19:19 AM
door frame off-set
Wed, Mar 11, 2015 at 7:42:20 AM
DOOR & FRAME, NEW VS. EXISTING
Thu, Jun 28, 2012 at 1:18:56 PM
Page generation time: 1.2695
