Forums >> Revit Systems >> Technical Support >> Ceiling Lights delete when edited
Tue, Dec 18, 2007 at 4:31:13 PM | Ceiling Lights delete when edited
derxaj
3.5 Stars: 3 Votes
This could be a common question but does anyone else have serious issues when they edit a ceiling that has light fixtures already hosted to it?  Most of the time Revit trys to delete the hosted lights.  This has been a problem for us since Revit 8.1 and I'm wondering if its ever been addressed or anyone has any tricks that work all the time to resolve this problem.  It seems like hosted families in ceilings are just very unfriendly and it is such a headache because this usually happens near the end of a project when everything is set but then we realize that a ceiling has to be edited for whatever reason and then Revit wants to delete all instances of lights in the ceiling...any ideas?
Thu, Dec 20, 2007 at 8:23:15 PM | Ceiling Lights delete when edited
Tmifsud
Strange issue.  I haven't run into it.  Editing grid with lights attached hasn't caused any problems for me.  I wonder if it is related to the light fixture family.  Have you tried different light fixture families with the same result?
Troy - myCADD
Fri, Oct 7, 2011 at 6:36:16 AM | Ceiling Lights delete when edited
mikeinsverige
Using Revit Arch 2011, I am having this same problem. Happens with two different light families. I edit the corner shape of a ceiling, or move one boundary, and it wants to delete lights, or shift them all.Any solutions?
Fri, Oct 7, 2011 at 7:51:39 AM | Ceiling Lights delete when edited
AbsoluteBIM
AbsoluteBIM Avatar
4 Stars: 4 Votes
you could use face based components instead of ceiling based. When you make changes to the ceiling, the components may lose their association but not be deleted. Downside of this is that your lights wont shift with the grid pattern if you alter it and that is a pain!
Ceiling lights not working
Thu, Feb 26, 2009 at 4:10:57 PM
Ceiling Lights don't self-illuminate
Mon, Oct 17, 2011 at 10:21:44 AM
ceiling plane/floor/can lights
Sat, Dec 19, 2009 at 12:35:31 AM
Lights in Ceiling Grid
Sat, Feb 4, 2006 at 12:49:43 PM
Lighting
Thu, May 29, 2014 at 7:28:06 AM
Page generation time: 3.5987
