Forums >> Revit Building >> Technical Support >> New Windows in New Walls
Mon, Dec 17, 2007 at 12:58:13 AM | New Windows in New Walls
rcobbjr
3.5 Stars: 3 Votes
I am using Revit 2008. I took the Andersen Casement windows and added them to my model. I changed the "information" regarding the windows such as the manufacturer, rough opening, finish opening dimensions for the windows and saved them as a different family (Reliabilt).
I modified the Generic wall that I was using and replaced it with a stucco wall. When I replaced the Generic wall with the new stucco wall, my ReliaBilt (once Andersen) windows were deleted one by one as a changed the wall. Why is this happening?
The Andersen windows work in the stucco wall but the modified Andersen windows (modified to Reliabuilt) do not. Why not?
Tue, Dec 18, 2007 at 11:47:42 AM | New Windows in New Walls
If you only changed values in your type menu, you should not have had a problem if the initial family was built correctly.  The problem is there is no easy answer for your problem.  You might look at the opening cut definition in the family.
Tue, Dec 18, 2007 at 2:30:02 PM | New Windows in New Walls
rcobbjr
3.5 Stars: 3 Votes
How do I check the opening cut definition? Thanks for the response.
Can only square panels in curtain walls be converted to windows?
Wed, May 16, 2012 at 2:22:01 PM
Can't figure it out, Windows are not cutting my walls
Fri, Apr 30, 2010 at 12:39:16 PM
Windows and Furred out Walls
Wed, Oct 14, 2009 at 7:47:11 AM
curtin walls to windows....
Tue, Sep 2, 2008 at 7:06:30 AM
Windows on Curved Walls
Wed, Nov 16, 2005 at 5:08:27 AM
Page generation time: 0.8774
