18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Circular Windows
14 Posts No Rating |
Hie using REvit 2008 try to make a circular windows so I edit the profile it's OK but the wall still a square and i can't achieve to select the ligne to edit the shape of the square hole  there is a tutorial but i don't get it how can I make a circular hole in my wall while placing my windows [URL=http://img136.imageshack.us/my.php?image=circulaireea6.jpg][IMG]http://img136.imageshack.us/img136/8541/circulaireea6.th.jpg[/IMG][/URL] thx
----------------------------------- perfect |
You need to change the "Opening Cut" object. You should be able to select this in plan or 3d. It will be shown as a line at the edge of the wall. In 3d it show highlight like a Void Object. Once you get it selected you can either edit it or erase it and use the Opening tool to create your own opening object.
Great work fine but how i can cote the diametre of the circle to make the windows paramétrical cause the center its the only point i can cath for the mesures cotation but for now its cool  thx
If I understand your question correctly, you want to be able to adjust the diameter parametrically. If so use a Radius type dimension and apply a paramter to it. Then to make the diameter parameter you can add a parameter and use the fomula (Radius * 2) to be able to control the window by diameter.
circular beams, walktrough, windows etc |
Wed, Jan 31, 2007 at 6:36:00 AM
Circular Arch |
Tue, Jul 21, 2015 at 9:06:15 AM
Circular Beam |
Thu, May 15, 2008 at 12:40:23 PM
13
circular stairs |
Mon, Mar 24, 2008 at 4:40:37 PM
circular pergola |
Mon, Apr 29, 2013 at 10:40:27 AM
