Forums >> Revit Building >> Technical Support >> Editing and creating new wall types
Fri, Dec 14, 2007 at 9:04:05 AM | Editing and creating new wall types
Coffeefiend
Hello all. The project that I'm working on uses a type of compound wall that I've been unable to find in any Revit families. Is it even possible to load different wall types into a project? I notice that when you select "Component", the "Load" button appears so that different families can be uploaded; however, no such button appears when the "wall" tool is selected. Just for reference, the wall I want to model is the Tacoma compound wall system. It's constructed of units made of two panels of heavy-duty foam with a peice of plastic connecting them, creating a gap into which concrete is site-poured once the panels are assembled. The result is a very strong bearing wall that is self-insulating. Also, I'm using Revit 2008 (in case the version matters). Thanks everyone, and happy holidays!
Fri, Dec 14, 2007 at 9:10:24 AM | Editing and creating new wall types
JHanby
3.5 Stars: 3 Votes
You can transfer wall types from model to model using the "Transfer Project Standards" under the file pull down menu.  If you don't have the wall type in a model, you would need to make the wall type.  I would make the two layers of heavy-duty foam with a layer of concrete in the middle.  The plastic connecting pieces might just have to be shown with detail components.  HTH
Fri, Dec 14, 2007 at 9:36:42 AM | Editing and creating new wall types
Coffeefiend
How do I go about modeling a new wall type? Is it the done the same way a new furniture family is made?
Fri, Dec 14, 2007 at 9:47:10 AM | Editing and creating new wall types
JHanby
3.5 Stars: 3 Votes
What I do is pick a similar wall. Hit the edit button. Then duplicate it, calling it what I want and then modify it how I need it.
Fri, Dec 14, 2007 at 10:17:54 AM | Editing and creating new wall types
Coffeefiend
I got it- thanks a lot!
Creating a Curved Wall via Massing
Sat, Jun 2, 2012 at 11:56:47 PM
How do I make custom wall types publicly accessible?
Sun, Apr 4, 2010 at 2:17:08 PM
Changing line types and styles in cross section views, wall types etc...
Wed, Apr 12, 2006 at 12:52:32 AM
Copying Arch Wall Types
Tue, Aug 14, 2012 at 9:18:26 AM
CREATING NEW STRUCTURAL WALLS
Sun, Sep 7, 2008 at 2:01:55 PM
Page generation time: 0.8941
