Forums >> Revit Building >> Technical Support >> Wall Visibility
Thu, Dec 13, 2007 at 3:09:06 PM | Wall Visibility
BRIANDHADLEY
1 Stars: 1 Votes
Using Revit Architecture.  In the attached plan I have a roof plan with the floor plan underlayed.  Can anyone tell me why some of the walls are not visible?
Thu, Dec 13, 2007 at 3:23:31 PM | Wall Visibility
jonblaze451
1 Stars: 1 Votes
What attached plan?  In which view can you not see the walls?
Thu, Dec 13, 2007 at 3:43:04 PM | Wall Visibility
BRIANDHADLEY
1 Stars: 1 Votes
I will try to attach it again.  The roof plan is the what my question pertains to.
Thu, Dec 13, 2007 at 5:26:52 PM | Wall Visibility
BRIANDHADLEY
1 Stars: 1 Votes
Here is a pdf of the roof and the floor plan.  Has anyone experienced this problem?
Fri, Dec 14, 2007 at 8:57:40 AM | Wall Visibility
UserError
UserError Avatar
3 Stars: 1 Votes
Looks like only the exterior walls are not showing up. Are they on a seperate workset that is turned off?
Fri, Dec 14, 2007 at 10:01:51 AM | Wall Visibility
BRIANDHADLEY
1 Stars: 1 Votes
No.  All on same workset.
Fri, Dec 14, 2007 at 10:23:55 AM | Wall Visibility
JHanby
3.5 Stars: 3 Votes
Are the wall attached to the roof?
Fri, Dec 14, 2007 at 11:08:11 AM | Wall Visibility
BRIANDHADLEY
1 Stars: 1 Votes
Yes they are.  Does it make a difference?
Fri, Dec 14, 2007 at 12:18:48 PM | Wall Visibility
jonblaze451
1 Stars: 1 Votes
Do you want to see your ghosted walls in your roof plan?
Fri, Dec 14, 2007 at 12:47:08 PM | Wall Visibility
BRIANDHADLEY
1 Stars: 1 Votes
Yes
Fri, Dec 14, 2007 at 1:01:43 PM | Wall Visibility
#11
jonblaze451
1 Stars: 1 Votes
I am not sure on this problem, but have you tried detaching from the roof?  I would recommend checking your visibilty/graphics overrides.
Fri, Dec 14, 2007 at 1:15:32 PM | Wall Visibility
#12
BRIANDHADLEY
1 Stars: 1 Votes
The problem seems to be caused by the walls being attached to the roof.  But I need them attached to the roof for my elevations and 3d views.
Fri, Dec 14, 2007 at 1:53:53 PM | Wall Visibility
#13
jonblaze451
1 Stars: 1 Votes
One idea is to detach for that view, if the walls can be seen after detaching, and reattach for the other views when you print.  It is extra work, but I have run into doing extra things in Revit just for graphic reasons.
Wall Core Visibility
Thu, Oct 9, 2008 at 11:53:58 AM
Turn off wall visibility on upper floors...
Fri, Mar 4, 2011 at 2:24:23 PM
Wall Component Visibility
Tue, Sep 9, 2008 at 10:03:23 PM
Wall section visibility
Thu, Nov 16, 2006 at 12:27:58 PM
Punched hole in shear wall visibility issues
Tue, Dec 26, 2006 at 4:19:43 PM
Page generation time: 1.0794
