Forums >> Revit Building >> Technical Support >> revit linking
Thu, Dec 13, 2007 at 12:37:58 PM | revit linking
elvis
hi all,
if i link a revit file in a model,
i do have to override for all views individually some settings [for example: to hide all annotations], what is the best way so that i do not have to set this for each view "custom"!
 so inserting a revit model with an graphical override "for all views" is that possible?
Fri, Dec 14, 2007 at 8:19:39 AM | revit linking
elvis
is this a stupid question?
Fri, Dec 14, 2007 at 8:52:53 AM | revit linking
UserError
UserError Avatar
3 Stars: 1 Votes
I don't know about automating that particular task and as far as I know, you cannot graphically override a revit model upon import. My suggestion is to either set up a view template for those views or to link an autocad reference with only the layers you want visible.
Someone else might have a better answer though.
Fri, Dec 14, 2007 at 3:20:25 PM | revit linking
elvis
stange though,
imagine, I insert open stairs in a plan as a revit link, that means that in all sections and elevations i manually have to put  a visual override to for example annotations etc!
 even worse, i have an urban site where I insert individual appartments as revit links!, i copy those 25 times, when i generate one section i see hunderds of levels [because each inserted revit link shows its own levels] , now i have to customize in the revit links menu all links individually to set for example the levels off! I cannot selectmultiple links to make an graphical override!!
very time consuming,
no alternatives?
Mon, Dec 17, 2007 at 6:24:18 AM | revit linking
UserError
UserError Avatar
3 Stars: 1 Votes
Yes, it can be time consuming at first but once you set up an elevation view templete you can apply that to your other remaining elevations at the same time.
As far as linking other modeling elements (your stairs), I am not sure. My preference isn't to link small items like that into the main model.
Mon, Dec 17, 2007 at 11:55:03 AM | revit linking
elvis
thanxs for the help,
 let's consider this item as a wishlist item:
graphical override for multiple revit-links!
grtz
Linking models with multiple sites
Wed, Dec 6, 2017 at 9:43:09 AM
DWG linking into revit
Mon, Jun 9, 2014 at 7:11:38 AM
Linking Revit Files for Sheet Coordination
Fri, Jul 10, 2009 at 11:09:09 AM
Linking Revit Architecture files
Sun, May 12, 2013 at 11:05:15 AM
Linking Other Models
Tue, Aug 31, 2010 at 1:35:54 PM
Page generation time: 2.0168
