Forums >> Revit Building >> Technical Support >> Curtain wall sliding door
Sun, Feb 27, 2005 at 9:55:40 AM | Curtain wall sliding door
gimmecat
I'm trying to make a sliding door for a curtain panel. I'm using the shop front double door family for this and I've done the door leafs. They can be put in the panel but for some reason i don't know they don't occupy the whole panel. Just the height at which they were done. Im leaving the file in case someone can help me. Oh, there's no glcurseon the door yet because I'm testing with it.
Sun, Feb 27, 2005 at 5:45:32 PM | RE: Curtain wall sliding door
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Select the top reference plane in elevation and drag it up... Notice the panels don't come with it? Now select the panels and drag the top node to lock with top reference plane then hit the padlock button... Do the same thing for the other panel... HTH.
Mon, Feb 28, 2005 at 4:26:06 PM | RE: Curtain wall sliding door
gimmecat
GREAT! Now I can make my sliding door panels! :D Thanks!!! (you don't imagine just how much time I spend around this one Puh)
Fri, Jul 25, 2008 at 10:31:57 AM | Curtain wall sliding door
Mindblindreaper
Mindblindreaper Avatar
You should post the family for that Puh, I cant seem to find a decent one.
Knowledge is power. Power corrupts. Study hard, be evil.
Curtain Wall Door
Mon, Aug 4, 2008 at 3:23:36 PM
Sliding door for Storefront wall
Mon, Mar 7, 2011 at 5:48:43 PM
Curtain Wall Panel to Curtain Wall Door
Revit refuses to load curtain wall door.
Tue, Feb 9, 2010 at 12:55:10 PM
Curtain Wall sliding door family not centering
Mon, Oct 5, 2015 at 6:19:33 PM
Page generation time: 1.8094
