Forums >> Revit Building >> Technical Support >> Corner Trim
Wed, Dec 12, 2007 at 4:56:30 PM | Corner Trim
BRIANDHADLEY
1 Stars: 1 Votes
How is the easiest way to add vertical trimboards to the corners of a building?
Thu, Dec 13, 2007 at 12:05:51 PM | Corner Trim
kesflower
3.5 Stars: 11 Votes
I'd say the easiest way is to make an external trimboard family and then load it into your project.  Either make a hosted family with the exact trim profile you want, or download the generic corner board family here on revitcity.  Much easier to use a family than to create each one in place.
Best of luck.
Ruth Rau
Main Street Architecture, P.C.
Thu, Dec 13, 2007 at 12:52:47 PM | Corner Trim
jterrell
3 Stars: 5 Votes
I use a column family (best if you unchedk 'automatically join' in the family types and parameters) that way I can set a lower and upper reference level. Works just fine.
Thu, Dec 13, 2007 at 1:59:06 PM | Corner Trim
BRIANDHADLEY
1 Stars: 1 Votes
Can you create it as a wall hosted family or is that only horizontal?
Corner Trim with Vertical Sweeps
Thu, Aug 31, 2017 at 2:32:51 PM
trimming trim corner.
Wed, Feb 1, 2012 at 12:09:41 PM
trim/extend to corner
Thu, Nov 4, 2010 at 6:10:31 AM
Help! Forgot how to trim with a radius corner.
Mon, Jan 8, 2007 at 8:25:35 AM
corner trim
Fri, Apr 2, 2004 at 2:17:39 PM
Page generation time: 5.3007
