25 Users Online (23 Members):
Forums >> Revit Structure >> Technical Support >> Dummy Callouts, are they possible?
19 Posts No Rating |
Is it possible to make a dummy callout on a plan view that you can input your own detail number & sheet number on? For instance if I imported a detail from CAD & wanted to call it out on the floor plan. Could I add a detail callout & edit it or can you add one as a detail component or would I just have to draw one up w/ detail lines or something? Also, is it possible to have a detail callout show up in multiple places on a floor plan for the same detail? Thank you to anyone that takes the time to respond!
Import your CAD detail into a new Drafting View. When you pick Section, Elevation or Callout look at the Options bar. Check the reference other view and pick the name of your Drafting View. This way it is a true reference (i.e., it updates the sheet and detail number as you place it or move it. You can do this as many times on a sheet as you want so that you have multiple tags referencing the same detail/view. No need for the dummy tags for that.
Excellent! That helps a lot! Thank you very much.
Hello, not sure if this helps.
We have a different situation where we need to reference views from another linked Revit model.
In the process, we created a Dummy Callout Boundary and Dummy Tag to suffice.
Link to screencast provided.
https://screencast.autodesk.com/main/details/20f5a91f-8279-4ad3-8911-f6187d23bf41
Cheers
Joaquim
Revit Architecture 2013
ArchiCAD 16 Win
Windows 7 Enterprise 64-bit |
Are Callouts Vew Specific? |
Wed, May 12, 2010 at 3:56:06 PM
Dummy Callout Heads |
Tue, Jan 28, 2014 at 3:35:50 PM
HELP! callouts are not visible!! |
Sat, Feb 16, 2008 at 12:17:21 PM
Callouts and Callout Sim Views |
Thu, Sep 12, 2013 at 10:41:57 AM
multiple section callouts |
Wed, Jun 4, 2008 at 9:04:18 AM
