Forums >> Revit Building >> Technical Support >> Odd Wall join. Can't get Revit to work right
Wed, Dec 12, 2007 at 10:46:41 AM | Odd Wall join. Can't get Revit to work right
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
I have a wall that is join off axis and when I try to beef up the inner wall to make the corner 90 degrees Revit can't joing them.  Any ideas on how to accomplish this?  Thanks.
Denver, CO
Revit Architecture
Wed, Dec 12, 2007 at 11:51:07 AM | Odd Wall join. Can't get Revit to work right
jterrell
3 Stars: 5 Votes
Create an in-place column family. Make sure when you are creating the family, you go to "Family Categories and Parameters" and select "Automatically join". See the attached images.
Wed, Dec 12, 2007 at 12:10:57 PM | Odd Wall join. Can't get Revit to work right
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
awesome...you rock.  Thanks for the help
Denver, CO
Revit Architecture
Wed, Dec 12, 2007 at 12:42:06 PM | Odd Wall join. Can't get Revit to work right
coreed
coreed Avatar
4 Stars: 16 Votes
you can do the same thing with an in-place wall and join geometry
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Dec 12, 2007 at 1:02:43 PM | Odd Wall join. Can't get Revit to work right
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
Yes you can do that...but I notice that it doesn't have the option to "attach" under the category settings.  Am I missing something.  Because I'd much rather have these on the wall category to turn on and off appropriately.
Denver, CO
Revit Architecture
Wed, Dec 12, 2007 at 1:45:10 PM | Odd Wall join. Can't get Revit to work right
coreed
coreed Avatar
4 Stars: 16 Votes
you have to manually join the walls with join geometry after they are both created. like you said there is no auto option like the columns.
HTH
Edited on: Wed, Dec 12, 2007 at 1:45:51 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Dec 12, 2007 at 2:46:34 PM | Odd Wall join. Can't get Revit to work right
lorne17
lorne17 Avatar
3.5 Stars: 7 Votes
cool thanks.
Denver, CO
Revit Architecture
Section of wall in length axis: join function doesn't work
Mon, Nov 14, 2011 at 1:31:41 AM
Separating wall/ external wall junction
Wed, Nov 9, 2005 at 9:44:26 AM
walls won't join
Fri, Oct 31, 2008 at 2:31:33 PM
Line Based Family Won't Join at Ends
Mon, Apr 10, 2023 at 8:13:57 AM
IN PLACE WALL WON'T JOIN TO ROOF
Thu, Jun 14, 2012 at 12:21:16 PM
Page generation time: 4.2273
