Forums >> Community >> The Studio >> Curved Masonry Walls
Wed, Dec 12, 2007 at 9:38:27 AM | Curved Masonry Walls
jonblaze451
1 Stars: 1 Votes
My question is related to an actual masonry wall, not a Revit wall.  Do problems often arise from curved masonry walls, i.e. joinery, cost, or anything else.  I have not had experience from a actual mason, but a long 160' curved wall would seem to be better replaced by a diagonal.
Thu, Dec 13, 2007 at 12:17:27 PM | Curved Masonry Walls
kesflower
3.5 Stars: 11 Votes
With actual curved walls, your cost and joinery and the difficulty of integration with other walls is entirely dependant on the skill of your mason and his/her crew.  Most masons will charge a premium for a curved wall because of the care they need to take to get it right, but if you've got a good mason, that upcharge will mean that the work is of such a quality that there will be minimal problems with integration of other wall types.  I think that if you want a curved wall, design a curved wall and then get several prices from several masons.  If you anticipate that in your area there will be too much of a price premium for that curve, then think ahead and make mental note of how you would need to design it with a diagonal wall.  But if you're using Revit for the redesign, it shouldn't take too much to change the wall at a later date.  Design what you want, you may be surprised by the skills of the craftsmen around you!
Ruth Rau
Main Street Architecture, P.C.
concrete wall and masonry wall to have different lineweights
Thu, Jan 6, 2011 at 12:39:04 PM
Creating different Masonry walls with different finishes
Sat, Feb 4, 2012 at 9:07:02 PM
Aligning hatch pattern on elevations
Wed, Jan 30, 2008 at 3:29:51 PM
masonry walls?
Tue, Jun 22, 2010 at 5:35:51 PM
curved curtian walls
Mon, Nov 13, 2006 at 6:19:28 AM
Page generation time: 0.3828
