Forums >> Revit Building >> Technical Support >> Roof Material
Wed, Dec 12, 2007 at 8:47:57 AM | Roof Material
BRIANDHADLEY
1 Stars: 1 Votes
Using Revit Architecture.  In a roof plan how do you turn off the shingle roof pattern?
Thu, Dec 13, 2007 at 12:23:31 PM | Roof Material
kesflower
3.5 Stars: 11 Votes
In your roof plan, go to View Properties - Visibility/Graphics Overrides - Model Categories - click to highlight Roofs, then under Projection/Surface - Patterns, click Override and in the window that pops up, unclick the Visible checkbox.
 This is a new placement from previous versions.  You turn off floor surface patterns and wall patterns in elevations the same way.
Ruth Rau
Main Street Architecture, P.C.
Thu, Dec 13, 2007 at 1:55:59 PM | Roof Material
BRIANDHADLEY
1 Stars: 1 Votes
I don't have the Projection/Surface Pattern option.
Thu, Dec 13, 2007 at 2:11:33 PM | Roof Material
kesflower
3.5 Stars: 11 Votes
When you highlight Roofs, the two columns to the right are your Projection/Surface pattern options.  Click Override in the 2nd column to the right.
Ruth Rau
Thu, Dec 13, 2007 at 2:42:22 PM | Roof Material
BRIANDHADLEY
1 Stars: 1 Votes
Got it.  Thanks, I guess I'm just blind.
Adding Material to Roof trim? RAC 2009
Mon, May 12, 2008 at 1:57:10 PM
Standing Seam Metal Roof Material
Tue, May 19, 2009 at 9:58:48 AM
Changing roof colour / material
Wed, Feb 14, 2007 at 6:18:20 AM
rotate material on fascia
Mon, Nov 23, 2015 at 10:29:03 AM
Flat Concrete Tile Roof
Tue, Oct 29, 2013 at 10:31:52 AM
Page generation time: 0.3437
