18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Adding views to a sheet - get all the clip rejoins the same?
64 Posts No Rating |
Im adding my views to a sheet but it is looking a little mish mash as i dont seem to be able to replicate how much i have clipped from say the ground floor to the first floor. Is there a way of doing this?
I think what you are looking for is "Dependent Views". If your plan is too large to fit on one sheet, rather than simply duplicate the view and crop, use "Duplicate as Dependent". Each dependent view is listed in a tree structure under the primary view and if you make the crop regions visible you can see the crop regions of each dependent view. Create a seperate dependent view for each sheet. Get one floor set up as desired and then you can apply that to other levels by right clicking over the primary view and using the "Apply Dependent Views" function. Hope this Helps. Troy - myCADD
adding views to sheet |
Mon, Jun 30, 2014 at 3:13:29 PM
adding views to a sheet from another file... |
Tue, Jan 3, 2006 at 10:40:04 AM
Revit 2014 Clipping views on a sheet |
Wed, Nov 19, 2014 at 12:59:54 PM
13
Sheet Underlay |
Fri, Sep 12, 2014 at 2:13:25 PM
Save a sheet of drafting views |
Wed, Mar 1, 2017 at 5:34:28 PM
