Forums >> Revit Building >> Technical Support >> Total # of sheets/ Wind Category: creating to place on titleblock
Tue, Dec 11, 2007 at 7:25:38 PM | Total # of sheets/ Wind Category: creating to place on titleblock
stylewise
Hi everyone, I am just new to all this shared parameters/global sharing on titleblocks. I do not know how to create the following to have on a titleblock.
1. Total number of sheets (Where I can change the number in Project Settings would be just fine)
2. Wind category ( same as above)
I would like to have each label be global and once changed in Project Settings, changes globally on every single sheet.
 Any help would be wonderful...Smile (Revit Version: Architecture 200Shadey
Candice
Tue, Dec 11, 2007 at 8:24:24 PM | Total # of sheets/ Wind Category: creating to place on titleblock
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Too easy Smile
 1.  Create a shared parameter in your shared parameters file called "No of Sheets" set it to be a text parameter.
Now in your project, go to settings-->project parameters-->add-->Shared Parameter-->Select your shared Parameter-->Select the parameter to be "instance" and apply it to Project Information.  (its bests if you do this in your template file so you don't have to do it for every project).
 There you go...
2.  Same process as above with a different parameter name.
HTH.
Regards,
Chris.
Titleblock resized after export
Fri, Feb 7, 2014 at 8:40:39 AM
Sheet # of 'total number of sheets'
Fri, Nov 16, 2007 at 6:59:54 AM
How do you share a parameter between several different sheets?
Thu, Nov 10, 2016 at 3:15:54 PM
Getting Titleblock in centre of page
Tue, Mar 30, 2010 at 7:13:05 AM
Sheet 'X' of 'Total Number of Sheets'
Wed, Jun 5, 2013 at 4:39:34 PM
Page generation time: 0.5337
