Forums >> Revit Building >> Technical Support >> GRID AND SECTION VISIBILITY
Tue, Dec 11, 2007 at 2:57:38 PM | GRID AND SECTION VISIBILITY
vshum
I have a building that contains curved walls, angled walls, and an orthogonal column grid.  Is there a way to make the grid and sections cuts visible on elevations that cannot be perpendicular or parallel to the grid?  I appreciate the assistance.
Thu, Dec 20, 2007 at 8:03:27 PM | GRID AND SECTION VISIBILITY
Tmifsud
I have looked into this previously.  I have not found a way to make grid lines appear in views which are not aligned with the grids.   As a work around, you can draft the grid lines.  In order to determine the correct position in the elvation view I switched back to plan and created a reference plane which is perpendicular to the elevation line.  Next, switch back to the elevation and draft a line over top of the reference plane.
Hope this helps.
Troy Mifsud- myCADD
Column grid lines disapear in one section view.
Thu, Aug 2, 2007 at 5:00:17 PM
Grid Partial Visibility
Wed, Aug 3, 2016 at 1:08:39 PM
Section Marker Visibility
Fri, Nov 6, 2009 at 12:37:11 PM
column grid visibility
Wed, Nov 15, 2006 at 3:43:13 PM
Reference plane visibility in section
Mon, Aug 27, 2018 at 7:11:50 AM
Page generation time: 4.9271
