12 Users Online (10 Members):
Forums >> General Discussion >> Revit Project Management >> E-transmitting in revit?
2 Posts No Rating |
Is there a feature in Revit that allows you to bundle all of the information in a model together, much like the e-transmit in Autocad. I've posted our model to an FTP site, but the consultants are unable to see the linked files. Any suggestions?
if you are talking about a revit model with linked revit files, you can simply click on your linked file and select Bind from the Options bar on the top.
there is no E-transmit feature to Revit like in Autocad that i know of. But as Eldados said there is Bind HTH
Revit 2009 in 3D Studio Max Design lighting issues |
Mon, May 5, 2008 at 6:03:59 AM
finding object |
Mon, Aug 12, 2013 at 10:01:49 AM
Revit for Construction Documents [ 1 2 ] |
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ] |
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ] |
Thu, Jan 6, 2011 at 3:25:02 PM
18
