Forums >> Revit Building >> Technical Support >> Pattern/Hatch Line Weights
Mon, Dec 10, 2007 at 6:10:43 AM | Pattern/Hatch Line Weights
johnpaulrogers
Hi, I've been searching the forums for a while to try and find a recent answer to this question but only found answers that were almost a year old and I'm wandering whether it had been sorted.  I'm using Revit 2008.   Is it possible to change the line weights of patterns/hatches used in filled regions and material surface patterns?  I've set the colour to black but the the lines still appear too faint for what I need.  I've looked in object styles, line style and lineweights, but can't find an obvious control for hatch lineweights.
thanks
John-Paul
Thu, Dec 13, 2007 at 12:31:43 PM | Pattern/Hatch Line Weights
kesflower
3.5 Stars: 11 Votes
Not changed that I know of.  But you can take a hatch pattern from CAD and make a custom hatch in Revit.  Anyone know how to do that?
Ruth Rau
Main Street Architecture, P.C.
Line weights for hatch?
Mon, Mar 23, 2009 at 2:24:48 AM
hatch pattern
Fri, Mar 28, 2014 at 1:45:01 PM
hatch pattern in material anomolies
Fri, Aug 26, 2016 at 9:35:26 AM
Surface Pattern Line weight of walls
Wed, Nov 4, 2009 at 4:22:31 PM
Vertical hatch pattern line alignment on wall ends
Wed, Mar 14, 2012 at 10:04:07 AM
Page generation time: 0.3960
