Forums >> Revit Building >> Technical Support >> Help needed with external brick leaf wrap to cover window frame. RA2008
Mon, Dec 10, 2007 at 5:24:53 AM | Help needed with external brick leaf wrap to cover window frame. RA2008
Gils
I'm sure someone already has had this issue.
 I'm trying to create window type that fits into brick cavity wall. External brick leaf should cover the window frame 20mm on each side as seen on the image. Image was taken from the help file so it is possible, but how?
 Thanks in advance.
Help required with wall wrap at window & door jambs
Fri, Oct 16, 2015 at 4:57:19 AM
Wall type wrap
Thu, Nov 26, 2009 at 3:25:40 PM
Separating wall/ external wall junction
Wed, Nov 9, 2005 at 9:44:26 AM
Demo Door Leaf not Frame
Thu, Nov 15, 2012 at 9:31:09 AM
Wall Joint
Wed, Oct 29, 2014 at 6:42:37 PM
Page generation time: 0.3188
