Forums >> Revit Building >> Technical Support >> Looking for RPC content
Sat, Dec 8, 2007 at 2:49:41 PM | Looking for RPC content
Icarus
Besides Archvision, is there another provider for quality RPC content?
Also, why doesnt this RevityCity forum have a "Revit Architecture" topic?
Mon, Dec 10, 2007 at 7:29:02 AM | Looking for RPC content
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
http://www.bionatics.com/Site/product/index.php3?langue=&UrlSuite=%2FSite%2Fproduct%2Findexc2.php3%3FCommunity%3D2%26ProductLineId%3D10
Mon, Dec 10, 2007 at 11:21:38 AM | Looking for RPC content
Icarus
Thanks,
I see these are all very well categorized plants. I am looking more for stuff like Archvision provides - people, office clutter, furnitire (the furniture library in Revit is way too small imo).
Also, I see that the site you provided provides content for other Autodesk products - any idea what type of library should I pick if I want it to work in Revit Architecture?
Mon, Dec 10, 2007 at 1:40:14 PM | Looking for RPC content
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
Sorry, I believe that easynat not work in Revit.
Archvision is the way to go, try RPCCreator to make your own.
Anyway no jaw-dropping images with Revit render.
Mon, Dec 10, 2007 at 2:20:59 PM | Looking for RPC content
Icarus
i see.
and what would you recommend as a renderer? this is not my main job, so i am looking for something relatively light and easy to use - not sure I am up for learning how to use 3ds.
Is Autodesk VIZ a recommended direction? or are there others? (for example, the standalone Accurender?)
Or do I have to try 3ds for jaw dropping images? I like jaw dropping... Smile
Can you tell with which software this was rendered?
http://www.whitetower.co.il/index.php?
Click Flats on the menu.
Mon, Dec 10, 2007 at 2:54:58 PM | Looking for RPC content
naranjo01
naranjo01 Avatar
1 Stars: 2 Votes
Relatively light and easy to use???? maybe Acurrender 4
Autodesk VIZ is a stripped down of 3ds max, Viz render is a stripped down of Autodesk Viz, so this may be relatively light and easy to use.
 In may case, I made good models in max Smile, but bad renders Sad
And for the images: Max, Viz, Lightwave, Maya or Softimage.
Sun, Nov 2, 2008 at 1:10:01 PM | Looking for RPC content
LAKRIT
try a search on:
www.turbosquid.com and/or www.fallingpixel.com; these sites host large collections of textures and 3D resources
Sun, Mar 15, 2009 at 8:14:00 AM | Looking for RPC content
rierie
Hi, It's been a while since this was posted, but I was wondering if anyone had success importing EASYnat plant (realistic) into Revit yet? I know naranjo thinks it cannot be done, but since it's been a while since he said that and there have been software upgrades, I was hoping that someone had figured it out.
I was able to start a new plant family, import the CAD file after exploding the file and making the PROXYGRAPHICS to 1 in AutoCAD. I'm not sure how to make it realistic from there?? (EASYnat only come in .dwg or 3ds, but I only own AutoCAD 2008 and Revit 2009.)
I was finally able to create a new super simple family from scratch, but this seems a lot more complicated!
Revit 2009 - RPC Archvision Content
Tue, Jan 6, 2009 at 10:46:29 AM
Non-ArchVision RPC Content
Thu, Dec 29, 2011 at 8:21:55 AM
importing other RPC content in revit 2009??? plz help
Sun, Oct 26, 2008 at 3:06:05 PM
I Can't use RPC content in Revit Architecture 2011
Fri, Jun 4, 2010 at 9:46:20 AM
RPC Content
Fri, Dec 9, 2005 at 10:24:42 AM
Page generation time: 2.6431
