Forums >> Revit Building >> Technical Support >> Door Tag Change
Fri, Dec 7, 2007 at 3:17:54 PM | Door Tag Change
jonblaze451
1 Stars: 1 Votes
I want to change my door tag from an oval to a circle.  I assume edit the family and make a new tag family, is that the only way?
Jonathan
Fri, Dec 7, 2007 at 4:50:53 PM | Door Tag Change
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
That is correct. You can also check in the downloads section of this site to see if there is one already created.
Fri, Dec 7, 2007 at 4:58:54 PM | Door Tag Change
jonblaze451
1 Stars: 1 Votes
Well, that was cake.  I wish some of the other Revit problems were that easy to solve.
about door tag
Sat, May 25, 2013 at 1:25:38 PM
Door Tag Locations.
Wed, Aug 24, 2011 at 12:48:11 PM
Residential Door Tag
Fri, Jul 7, 2006 at 8:18:54 PM
door tag exposing the door-width
Wed, Sep 16, 2009 at 4:52:04 PM
Door Tag Parameter-Need it to be the door opening number, not the door type.....
Thu, May 7, 2009 at 4:09:39 PM
Page generation time: 0.4825
