15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> type vs instance parameters
Is there a way to change a type parameter into an instance parameter in an existing family? I want to change the material of the cabinet families that come with revit without having to create a new type for every material.
Sure ... Just edit the family, select the parameter and change it from type to instance. If you have the family already loaded and used, it will not be replaced and this new family will show up as xxx2 or something like that. To fix, just select all instances of the old family - swap them to the new then you can delete the old one and rename the new one correctly.
Edited on: Fri, Dec 7, 2007 at 2:43:30 PM
Default Sheet Settings |
Fri, Jan 15, 2016 at 2:00:54 PM
Deleting Door Instance Parameters |
Fri, Oct 17, 2008 at 8:58:06 AM
Add Yes/No Instance Parameters to Test |
Mon, Aug 12, 2013 at 3:43:59 PM
Titleblock Parameter is now Instance instead of Type |
Tue, Feb 17, 2015 at 3:31:00 PM
type versus instance and fuzzy behaviour |
Mon, Apr 18, 2005 at 9:46:56 AM
