Forums >> Revit Building >> Technical Support >> Spiral Extrusions
Fri, Dec 7, 2007 at 9:05:14 AM | Spiral Extrusions
MarkBryan
I am using 2008, and have created a spiral staircase. The problem is, is that now I need to create the drywall underside, and I am not sure how to create this. I have tried spiral extrusions before and you can only edit them in one dimension. Help!
Thu, Jan 28, 2010 at 3:43:59 PM | Spiral Extrusions
charlotte240
charlotte240 Avatar
3.5 Stars: 3 Votes
USE A "RAMP" UNDERNEATH, MAKE NOTE OF THE MEASUREMENTS FROM UNDER THE TOP STAIR STRINGER TO THE FLOOR, AND THE START MEASUREMENT UNDER THE STRINGER.  DONE.
CRI
Sat, Jan 30, 2010 at 3:59:57 PM | Spiral Extrusions
emgeeo
3.5 Stars: 7 Votes
agreed
Mon, Feb 1, 2010 at 5:40:22 PM | Spiral Extrusions
charlotte240
charlotte240 Avatar
3.5 Stars: 3 Votes
also, have you tried to make a mass, and then convert mass to wall?
CRI
Residential Spiral Stair
Mon, Feb 16, 2015 at 10:02:06 AM
Help - curtain wall on spiral ellipse
Mon, Oct 11, 2010 at 6:02:04 PM
Beam attached to s spiral slab
Sun, May 26, 2013 at 7:07:46 PM
how to do a tubolar spiral?
Tue, Jun 19, 2012 at 8:11:22 AM
Joining extrusions
Tue, Jul 26, 2022 at 3:58:08 PM
Page generation time: 1.0368
