Forums >> Revit Building >> Technical Support >> Reducing elevation tag size
Thu, Dec 6, 2007 at 2:24:05 PM | Reducing elevation tag size
littlepants21
In Revit 2008 I am trying to draw interior elevations, the interior elevation room tags are much to large. I cannot figure out a way to reduce them. How do I reduce them? Thank you
Thu, Dec 6, 2007 at 4:51:45 PM | Reducing elevation tag size
stanmpd
stanmpd Avatar
4 Stars: 4 Votes
Go to the settings pull down menu and viewtags, select Elevation Tags from the flyout.
Pick the 1/2" circle and duplicate it calling it 3/8" Circle, or whatever you want to call it.  Set the width to coorespond to whatever you set the name to.  3/8" works well for us.
ok your way out and select elevations from the view menu.
Select any elevation, click Edit/New then duplicate and give it a new name.
In the Parameters under Graphics, change the elevation tag to your new 3/8" Circle. (or whatever size your new tag is)
 You will now have a smaller circle Elevation Tag to use.  I named ours Interior Elevation.
 Hope this helps
stanmpd
Belz A&C
Memphis, TN
Tue, Mar 4, 2008 at 1:07:20 PM | Reducing elevation tag size
Arkane308
Thanks this helped me out a lot I had not found that out yet and was getting really annoyed with the stupidly large interior elevation tags.  Thanks!
 Andrew
Tue, Mar 4, 2008 at 3:37:51 PM | Reducing elevation tag size
stanmpd
stanmpd Avatar
4 Stars: 4 Votes
I'm glad it worked for you, thank you
stanmpd
Belz A&C
Memphis, TN
Thu, Mar 6, 2008 at 6:33:54 PM | Reducing elevation tag size
rwhite
does anyone know how to eliminate the drawing title from the Elevation tag and only have the detail number show?
Thu, Mar 6, 2008 at 6:47:59 PM | Reducing elevation tag size
NKramer
4 Stars: 9 Votes
Somewhat along the same lines of the original post. Go to Settings- View Tags - Elevation Tags and uncheck the box for show View Name.
Nick
Thu, Mar 6, 2008 at 7:10:32 PM | Reducing elevation tag size
rwhite
that box is when i go to those settings.  could it have anything to do that when i insert an interior elevation tag i say to "reference another drawing"?  i only want the sheet number and detail number to appear.  thanks for the help, i appreciate it
Thu, Mar 6, 2008 at 7:23:03 PM | Reducing elevation tag size
NKramer
4 Stars: 9 Votes
If you want multiple types then you will need to duplicate it and make the changes to whichever one you want. It should not matter if you are refencing another view or not. Its just turning the view title off and on.
Nick
Thu, Mar 6, 2008 at 7:42:37 PM | Reducing elevation tag size
rwhite
at the moment the box to check/uncheck the "view title" or whatever is unchecked, yet the name still appears.  i'm confused
Fri, Mar 7, 2008 at 8:48:07 AM | Reducing elevation tag size
NKramer
4 Stars: 9 Votes
Make sure that you are editing the corect family type. The first one that opens up is normally the square but most people use the circle...
Otherwise youll need to post some screen shots to explain your problem.
Nick
Fri, Mar 7, 2008 at 11:56:12 AM | Reducing elevation tag size
#11
rwhite
PROBLEM SOLVED!!! THANK YOU VERY MUCH FOR ALL THE HELP!
Changing Size of Elevation Tag
Mon, Apr 9, 2012 at 9:40:20 AM
Changing the size of the interior elevation tag
Wed, Dec 20, 2006 at 12:26:41 PM
Incorporating a Spot elevation tag into a custom made pipe "size" tag
Fri, Dec 13, 2013 at 8:28:38 AM
reducing file size
Wed, Oct 11, 2006 at 4:01:48 PM
reducing file size when importing into VIZ 2006
Mon, Apr 3, 2006 at 12:24:33 AM
Page generation time: 0.9272
