15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Remove Ground Poche/fill pattern
In elevations showing the Topography...how do you remove the poche pattern? I tried to change the material but there is no cut pattern assigned to the material. The poche is still showing up?
Denver, CO
Revit Architecture |
The method I use is to right click on the Topography and Overide By element. This will allow you to make the cut pattern invisible.
if your elevation line is not cutting the topo, you also need to change your projection pattern.
**Using Revit Architecture 2009, 2011, and 2012** |
Stiar cut pattern or fill pattern. |
Sun, Feb 19, 2006 at 11:46:36 PM
Remove Fill Pattern |
Tue, Jun 2, 2015 at 8:25:45 PM
color scheme/fill pattern |
Mon, Jul 9, 2012 at 4:56:36 AM
Walls, Floors and Roofs to show hatch pattern AND color poche? |
Sun, Apr 29, 2012 at 12:24:19 PM
Scaling fill pattern |
Thu, Nov 17, 2011 at 4:01:24 PM
