15 Users Online (13 Members):
Forums >> Revit Systems >> Technical Support >> Problem seeing doors in reflected ceiling plan
1 Posts No Rating |
I have set up a reflected ceiling plan in an architecture view. I change the view range to show how I want the drawing to look. As soon as I change the views properties to be an Electrical Reflected Ceiling Plan, the doors all disappear and it acts as if the cut line is in some foreign location. No matter what I change the View Range to be, I cannot generate the same view as i could in the Architectural Ceiling Plan. Does anyone know what I might be doing wrong? Thanks ahead of time!
Check your VV or hidden items and see if the doors are turned off. Othewise you might need to post the file or at least screen shots to help people understand the problem.
8 Posts No Rating |
Yeah, my first thought is to double-check your VV settings. How are you making the electrical RCP? I'd approach this task by duplicating the Arch. Ceiling Plan; you retain the original Arch. plan, as well as getting something to start off with for making your Electrical plan with the exact same settings. Then, when changing settings in VV, you know exactly what you have turned on/off compared to the Arch. plan.
Reflected ceiling plan |
Fri, Mar 28, 2008 at 11:16:26 AM
Cannot open reflected ceiling plan |
Fri, Jan 9, 2009 at 2:23:07 PM
REFLECTED CEILING PLAN |
Thu, Jan 20, 2011 at 3:12:51 AM
Different Plan Title for Reflected Ceiling Plan |
Mon, Aug 1, 2022 at 4:28:33 PM
Can't Unhide Stubborn Wall |
Thu, Jan 10, 2013 at 8:28:20 AM
