Forums >> Community >> Newbies >> Curved Walls
Wed, Dec 5, 2007 at 2:13:45 PM | Curved Walls
Jessicaab
i would love to know how you make curved walls and can you?
Wed, Dec 5, 2007 at 3:12:32 PM | Curved Walls
IDN101
2.5 Stars: 3 Votes
Yes you can!
Instead of using the straight line tool (check out the Options Bar while in "wall mode"Winking, pick an Arc tool- simple as that.
 Try it now!
Regards,
Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Fri, Dec 7, 2007 at 11:45:46 AM | Curved Walls
jaylac2x
Jess and I are working on a project together. How do you make a curved roof? Is it possible? We made the curved walls just like IDN101 said to, but we can't figure out how to make a curving roof. Any help?
Mon, Dec 10, 2007 at 3:47:39 AM | Curved Walls
IDN101
2.5 Stars: 3 Votes
Curved roofs are a "little" more complicated than noraml flat / pitch roofs- but can definitely be done.
 When using the roof tool, use "roof by extrusion". You will then need to set up a vertical Work Plane, in which you can then sketch the shape of your curved roof.
 You could also use an "In Place" family for this. It all depends on excatly what type of curved roof you are trying to produce.
Regards,
Ian
www.RevitZone.com
Mon, Dec 10, 2007 at 3:02:54 PM | Curved Walls
jaylac2x
ok we did it! thanks a lot
curved curtian walls
Mon, Nov 13, 2006 at 6:19:28 AM
curved surface
Tue, Nov 6, 2018 at 7:03:42 AM
Sloping curved walls?
Thu, Apr 20, 2006 at 10:09:16 AM
Attaching Curved walls to underside of Curved Stairs
Wed, Sep 12, 2012 at 12:43:47 PM
Complex Curved Walls - please help
Wed, Mar 25, 2009 at 5:26:10 PM
Page generation time: 0.2990
