Forums >> Revit Structure >> Technical Support >> Concrete beams joining at expansion joint
Wed, Dec 5, 2007 at 11:25:41 AM | Concrete beams joining at expansion joint
SHATCHER
I have a slab with a perimeter beam. The slab has a 4" expansion joint. When I try to put the beams on eitherside of the EJ one of the beams keeps extending through the EJ to connect to the other beam end. It seems to be a tolerance issue. How can I get my beams to keep seperated and have the 4" EJ?
Tue, Jan 25, 2011 at 6:15:44 AM | Concrete beams joining at expansion joint
Daveybdab
Het shatcher. I got the same problem, anyone got a solution? the best work around i have at the moment is to cut the beams by face. This does produce the required gap but am not sure it this will be recognised as a gap if I use the model for any analysis.
Tue, Feb 8, 2011 at 2:04:44 PM | Concrete beams joining at expansion joint
emgeeo
3.5 Stars: 7 Votes
How thick is the expansion joint?
I typically use the trim-multiple and trim to the expansion joint edge.
Creating an expansion joint family
Sat, May 2, 2009 at 10:57:03 AM
Auto Join Concrete Column & Beams
Thu, Jul 1, 2010 at 2:08:30 AM
Concrete Beam Not Joining?
Fri, Jul 15, 2011 at 10:59:14 AM
Automatic extension of Beam
Tue, Jan 24, 2012 at 3:20:15 AM
Joining isolated foundations to concrete beams - 2009
Thu, May 7, 2009 at 1:43:52 AM
Page generation time: 0.1281
