9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> Floor Best Practices?
Almost 100% of tutorials the slab edges are draw at interiors side of wall like the images below, but in real life the wall lies in the slab. What is the best for Revit? if the slab is small the volume calculation is lower for cost estimates. thanks.
So when you create your slab, point to the wall with the offset set to whatever offset you want. The slab can be at the exterior, interior, inside of or outside of your wall. It's up to you.
Revit Groups Best Practices |
Tue, May 21, 2013 at 7:58:50 AM
Best Practices for extracting Bill of Quantities |
Mon, Apr 11, 2016 at 3:07:28 AM
Spot Elevation for a typical floor |
Wed, Aug 9, 2017 at 8:16:05 PM
When to pin, When to lock - Best practices |
Tue, Nov 27, 2007 at 8:43:11 AM
Worksets (Best Practices) |
Wed, Jan 25, 2006 at 9:36:24 AM
