Forums >> Revit Building >> Technical Support >> Converting Autocad files to Revit 2008
Tue, Dec 4, 2007 at 12:01:05 PM | Converting Autocad files to Revit 2008
Icarus
Hello,
My apologies if this is a repeating question - I was unable to find a suitable thread or solution.
I am very new to Revit, and I am trying to import files created by AutoCAD.
Specifically, I am trying to use two types of files, both with DWG extension.
One type, seems to be a 2D representation of a 3D object - I am attempting to import it so I can use it as a revit family.
The second type, is a complete floorplan designed with AutoCAD.
I manage to use the import feature, and bring the DWG into revit, but then I get lost.
The imported model is "just sitting there", and I am not sure what I should do in order for it to be usable in Revit.
I have the buttons on top saying "Full Explode" "Partial Explode" "Query" etc.
Any help or reference to a thread/tutorial would be greatly appreciated.
Thanks in advance.
Tue, Dec 4, 2007 at 12:59:43 PM | Converting Autocad files to Revit 2008
coreed
coreed Avatar
4 Stars: 16 Votes
you will not be able to endow your Autocad files with Revit functionality. use can you them as reference or details as autocad files. use as underlays to trace over etc.. but they will not function as Revits objects. Imported Autocad walls will not take on Revit walls functions.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Dec 4, 2007 at 1:03:30 PM | Converting Autocad files to Revit 2008
Icarus
Thanks a lot,
I suspected this will be the answer.
Converting Revit files to AutoCAD files
Wed, Sep 15, 2010 at 2:09:17 PM
how to import revit 2008 data to autocad 2008????
Tue, Apr 8, 2008 at 10:12:03 PM
Converting "Solidworks" files to Revit (or Autocad) format
Fri, Mar 20, 2015 at 7:36:17 AM
training files for 2008
Sat, Dec 24, 2022 at 4:48:32 PM
Importing AutoCAD MEP 2008 files into Revit Architecture 2008
Fri, Nov 16, 2007 at 1:27:47 PM
Page generation time: 1.3363
