28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> 2x4 ACT CEILING DISPLAY ISSUES
quick question- why would a 2x4 ACT ceiling be represented in ceiling plan oriented in one direction, but when rendered it alters the orientation to the opposite direction? i am not able to change the orientation when i sketch the ceiling initially using the tab or spacebar key- am i missing something?? hoping it is a glitch-
The ceiling represents itself in Revit views via the surface pattern applied to the material assigned to the ceiling. The rendered version of the ceiling is via the AAccurender material applied to the Revit material. You have limited control of the Accurender material inside of Revit. You can find the .jpg image being used for the rendering and turn it 90 degrees in Photoshop. You can also play with the material origin point a little inside of Revit. For better Accurender materials and tutorials go to www.accustudio.com To rotate the ceiling pattern Revit displays, TAB to select one of the line and issue the rotate command.
Tom www.reviteer.com http://twitter.com/Reviteer |
i will try the website first as i have already tried the tab controls- interesting that the two parts of the program do not talk to each other very well all the time- thank you
2 X 2 ACT ceiling in Residential Template |
Sun, Nov 23, 2008 at 8:56:07 PM
Ceiling Grid Issues |
Wed, Jun 30, 2010 at 5:20:25 PM
How to create a custom compound ceiling? |
Thu, Nov 5, 2009 at 12:53:14 PM
2x4 light in ACT |
Mon, Mar 9, 2009 at 5:40:12 PM
Ceiling grid rotates when mirrored, lights fixtures don't. |
Tue, Dec 20, 2011 at 2:49:43 PM
