Forums >> Revit Building >> Technical Support >> concept roof ( is it possible)
Sun, Dec 2, 2007 at 7:46:47 PM | concept roof ( is it possible)
Bobby616
hey all,
 I am having problems with a concept roof I am working on.. I have tried a few different ideas but cant come up with an answer. I have attached the concept as a pdf, the dimensions dont need to be correct I just need to know if it is possible. Not sure if a roof is the answer or massing, or any other ideas would be greatly appreciated. I am using Revit Architecture 2008.
 Thanks, rob
Mon, Dec 3, 2007 at 4:09:40 PM | concept roof ( is it possible)
ebtaylor
3 Stars: 2 Votes
your roof is possible, you can create your roof as a mass, then select roof by face!
Mon, Dec 3, 2007 at 4:29:18 PM | concept roof ( is it possible)
Bobby616
thanks,
Im happy to know its possible. would you be able to either send some intructions of what sort of massing u would use and how u would use it, or even better create the roof in a generic form so i would be able to edit it. thanks again.
 Rob
Mon, Dec 3, 2007 at 4:47:09 PM | concept roof ( is it possible)
NKramer
4 Stars: 9 Votes
You can just create a block mass, cut it up with voids and the click roof - roof by face. That should work.
Let me know if you figure out a good way to flash the scissors transition. Every roof that I have ever seen like that leaks like a sieve (at least within a few years).
The concept of warp
Thu, Sep 23, 2004 at 12:35:52 AM
Abstract roof
Mon, Apr 30, 2012 at 8:26:50 PM
Roof Pitch Tags
Mon, Feb 5, 2007 at 11:08:35 AM
The Revit concept for absolute beginners
Sun, Nov 21, 2010 at 2:31:47 PM
Roof design problems
Fri, Jul 9, 2010 at 7:30:00 AM
12
Page generation time: 2.5879
