10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Area Schedule
2 Posts No Rating |
I need to create an area schedule with different categories. I can do a running total for each category but how do i subtract an area (for exempted area) from the gross total?
UNDER THE FEILD TAB DO A CALCULATED FORMULA. WHAT EVER FEILD YOU CREATE IS NAMED ,YOU CAN SET A FORMULA TO SUBTRACT DIFFERENT CATAGORIES FROM EACH OTHER. OR WHAT EVER YOU NEED TO.
----------------------------------- PWD |
2 Posts No Rating |
I'm a new Revit user so thanks for your help. For the Area schedule, I was also wondering if I create a calculated value under the Field using the 'Yes/No' type, would I be able to write a formula where if the Yes option is checked, the area would be displayed and if the No option is checked, the area would be 0. If you can, what would that formula be?
admin
now you're getting into some fairly complicated formulas. Revit's help tool has a little tutorial on formula syntax... you should take a look at it.
Hiroshi Jacobs
The Catholic University of America |
Area Plan does not match Area from Materia/l Area |
Tue, Feb 13, 2018 at 7:50:03 AM
Wall Area Schedule |
Mon, Sep 19, 2011 at 3:44:22 PM
Area Schedules and Area Schemes - Revit 2019 |
Tue, Apr 2, 2019 at 7:41:56 AM
area calc schedule |
Fri, Oct 17, 2014 at 10:14:00 AM
Area Schedule Estimated Cost |
Fri, Aug 21, 2009 at 10:09:35 AM
