Forums >> Revit Building >> Technical Support >> calculating value formula problem
Fri, Nov 30, 2007 at 5:51:10 PM | calculating value formula problem
mike81
I'm trying to come up with a formula to help calculate the individual wall sq. ft. of each room.  so far I have figured out how to do this, but when different floor to floor heights are involved I can't seem to come up with the correct formula.Perimeter * 9'0".....works, but some floors are 8"0"so I need the formula to contain more than this and filter through the feild "Level", I thought the formula would be...Perimeter * IF ( Level = lower plan, 9'1", IF ( Level = main plan, 8'1", IF ( Level = upper plan, 8'1"Winking))
if anyone can help me it would be greatly appreciated.
p.s. it's in a room schedule, and the feilds are name, number, level, area, perimeter, floor finish, wall finish, ceiling finish, wall sq.ft.
Calculating two Formulas on the same row in a Schedule
Fri, Dec 17, 2010 at 7:22:56 AM
Calculating CFM on Return Ductwork problem
Mon, Dec 1, 2008 at 1:43:37 PM
Material Take Off Formula for length of studs at sloping wall?
Wed, Apr 2, 2008 at 10:13:18 AM
Elevation Formula
Wed, Apr 8, 2009 at 11:07:26 AM
pless help me (for Studies) Calculating quantities
Fri, May 6, 2016 at 1:29:25 AM
Page generation time: 0.4950
