Forums >> General Discussion >> Wishlist >> Corrugated Iron Sheeting
Fri, Nov 30, 2007 at 5:04:09 PM | Corrugated Iron Sheeting
Fyarch
I use a lot of corrugated iron (steel) sheeting for roofs and walls and I'm wondering if there's a 3D model of that sheeting? Generally the profile is 16mm high (0.63"Winking with crests at 75mm centres (3"Winking and the sheets are around 860mm (34"Winking wide overall. That becomes approx 784mm (31"Winking effective cover when the sheets overlap.
The particular project I'm doing at the moment has walls that have corrugated iron sections in the same plane, but the corrugations have different orientations to align with angles of those wall sections. As you can imagine, it loses a lot when the walls look like flat white planes rather than colored striated planes.
I imagine that a corrugated profile would add a lot to the size of a Revit file and slow things down, but maybe I could apply that as a wall (or a roof) that I could shut off most of the time.
 I hope someone can help.
Corrugated Iron roofs
Sun, Jul 31, 2005 at 10:26:14 PM
Drawing floor system using corrugated iron?
Mon, Apr 26, 2021 at 6:02:41 AM
Custom Orb wall
Sun, Oct 23, 2005 at 7:06:54 PM
corrugated roof
Fri, Jul 29, 2011 at 8:53:10 AM
11
HATCH LIBRARY
Mon, May 8, 2006 at 4:25:10 AM
Page generation time: 1.0983
