Forums >> Revit Building >> Technical Support >> Modifying the daystamp
Fri, Nov 30, 2007 at 11:23:01 AM | Modifying the daystamp
RFarley
Is there a way to modify the daystamp Revit Acrhitecture 2008 places on the sheet so it includes the file path? When I worked in a civil engineering office LDD has such a command under the express tools menu and it sure made finding existing files easier.
Thanks.
Fri, Nov 30, 2007 at 1:34:03 PM | Modifying the daystamp
JHanby
3.5 Stars: 3 Votes
I would just add the file parameter next to the date/time stamp like the attached view.
Fri, Nov 30, 2007 at 10:56:41 PM | Modifying the daystamp
RFarley
Hmm. The attached view does not help much since it is too small to see.
modifying fixed windows
Fri, Aug 7, 2009 at 10:29:22 AM
Modifying Families
Tue, Mar 10, 2009 at 9:55:47 PM
13
Dual Sloped Floor without Modifying Sub Elements
Thu, May 5, 2016 at 8:08:50 AM
Floor drain slopes adding lines to the slope when modifying sub elements
Tue, Oct 16, 2012 at 3:55:57 PM
Modifying Default Family Templates
Mon, Apr 26, 2010 at 2:20:23 PM
Page generation time: 0.6043
