Forums >> Revit Building >> Technical Support >> revit bldg 2008 - complex roof for commercial roof
Fri, Nov 30, 2007 at 8:52:51 AM | revit bldg 2008 - complex roof for commercial roof
skibum71
3 Stars: 1 Votes
good morning all.  i've read a few related posts, but still have a question on creating a compound slope for a roof.  i have steel beams/joists which slope in 2 directions.  imagine in plan, a rectangle with 3 points at HP steel, and the 4th point down about 2'.  Essentially i havea bay of 54'-1" x about 91', with 1/4" slope per foot in the 91' direction.  this gives a slope of about .41" per foot in the 54' direction.  i've manually slped the main girts, but when i try to add joists, i did so as "beam system".  this makes me pick a reference level.  i used HP roof, but then i have to manually calculate the elevation aof each joist along the sloped beam.  is there a way to create a warped plane?  that would make it easy to resolve both structure and roof issues, if i could simply attach these to the warped plane.  any help would be appreciated.
 Cryingto complicate issues, the one "long" bay along the building facade is not actually straight... see attached.  the bay of roof area i'm talking about is above the long span joists only)  in that view, the left hand bearing steel slopes down/away at 1/4" per foot.  right hand steel along cutrain wall and left steel above straight clerestory glazing are all at HP steel)
Fri, Nov 30, 2007 at 8:55:19 AM | revit bldg 2008 - complex roof for commercial roof
skibum71
3 Stars: 1 Votes
oops.  image got cropped
Sun, Dec 2, 2007 at 7:10:34 PM | revit bldg 2008 - complex roof for commercial roof
puzzle
4 Stars: 10 Votes
Have you tried making your roof from a floor. Then you could edit the points you need in 2008 that is
Edited on: Sun, Dec 2, 2007 at 7:41:31 PM
Macca
Sunshine Coast
QLD Australia
Sun, Dec 2, 2007 at 11:53:47 PM | revit bldg 2008 - complex roof for commercial roof
Erik
Sorry, I do not offer a solution to your question.  I do however find it amusing that a developed country like the US, still use the non sensical Imperial measures, when most of the enlightened world already saw the light some 120 years ago.  To me, your question was like reading Mongolian :-) Meant as a stir, not to offend :-) I am sure Mongolian is a very nice language :-)
Mon, Dec 3, 2007 at 6:22:48 AM | revit bldg 2008 - complex roof for commercial roof
skibum71
3 Stars: 1 Votes
puzzle...  how do you make a roof from a floor?  would that enable one to edit elevation of just one corner?  i also thought about making a compound mass, extruding from floor level, and then subtracting a void from that mass to give me a roof.  that might work too.  thanks for your input.
erik.  why waste everyone's time with that?
Why Roof Cutplanes are visible in RAC 2008 and Why not in Revit Building 9
Wed, Jul 16, 2008 at 10:34:18 AM
complex curved roof structure
Thu, Mar 12, 2009 at 1:11:49 PM
Join roof to multiples roofs
Tue, Jan 16, 2018 at 1:59:08 PM
Very Very Challenging Complex Roof
Wed, May 24, 2006 at 12:01:41 AM
HOW TO CREATE SHED TYPE ROOF IN COMPLEX/TRAPEZOIDAL FLOOR PLAN
Fri, Sep 20, 2019 at 11:10:56 PM
Page generation time: 1.8802
