Forums >> Revit Building >> Technical Support >> Spot dimension tags and thier relationship to ceilings
Wed, Feb 23, 2005 at 3:07:24 PM | Spot dimension tags and thier relationship to ceilings
cadmonkey
I am trying to use the Spot Dimension / Elevation tag to note the ceiling heights on my RCPs. When I place the tag in the middle of the room it returns the elevation of the top of the ceiling structure, but when I place the tag on the intersection of the ceiling and the wall it returns the elevation of the bottom of the ceiling assembly. For instance, I create a ceiling at 9'0" off of Fin Floor and a spot elevation tag in the center of the room reads 9' 2 1/4" while a tag at the edge reads 9' 0". Once I insert a tag on the edge and get the "correct" elevation I cannot move the leader off of the wall. What can I do, short of lowering all my ceilings to get the spot dimensions to read right?
Wed, Feb 23, 2005 at 5:29:12 PM | RE: Spot dimension tags and thier relationship to ceilings
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I wouldn't use spot elevations to define ceiling heights, I only ever use spot elevations to define u'side of slabs where there is no ceiling. To define ceiling heights use ceiling tags, they will report the height of the ceiling defined in its properties. HTH.
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:11 AM
litle spot
Sat, Apr 23, 2005 at 6:38:09 AM
Spot Dimension references are no longer valid
Mon, Dec 3, 2012 at 7:44:16 PM
Companies making thier own families...
Thu, Jun 11, 2009 at 8:48:52 AM
Spot Dimension Text
Tue, Jan 20, 2009 at 10:58:18 AM
Page generation time: 0.2539
