Forums >> Revit Building >> Technical Support >> default sill height
Wed, Feb 23, 2005 at 12:15:46 PM | default sill height
aabrmn
is there any way to define different default sill height for different family types inside a window family? While I am able to change other parameters like width and height I seem to not be able to change that... Any help is extremely appreciated.
Wed, Feb 23, 2005 at 5:26:13 PM | RE: default sill height
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
There is a default sill height parameter inside all window families, it is usually listed at the bottom under other category (depending what version you are using). HTH.
Windows Default Sill Height
Fri, Aug 26, 2011 at 12:51:41 PM
Window not visible, only opening - Revit 2008
Tue, Jan 22, 2008 at 10:30:53 PM
window schedule
Fri, Mar 3, 2006 at 8:35:11 PM
Setting Window Head Height
Fri, Feb 24, 2017 at 12:16:49 AM
14
Default Constraints in window family
Fri, May 4, 2012 at 7:13:48 PM
11
Page generation time: 2.5406
