Forums >> Revit Building >> Technical Support >> dimensions disappearing
Wed, Nov 28, 2007 at 8:49:00 AM | dimensions disappearing
Andrea1983
I need to split my plan up into multiple viewports.  However, when I do this the exterior dimensions disappear it the witness lines aren't in the viewport extents.  Does anyone have a workaround? I don't have an over all dimension plan and thus need to see the exterior dimensions in the viewports, even if they are cut off.
Thanks
Wed, Nov 28, 2007 at 9:35:05 AM | dimensions disappearing
coreed
coreed Avatar
4 Stars: 16 Votes
if you are using RAC2008 you might want to try using Dependent Views and adjusting your Annotation Crop Region.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Nov 28, 2007 at 9:42:54 AM | dimensions disappearing
Andrea1983
That is actually what I am doing......And I still have the dimensions disappearing
Edited on: Wed, Nov 28, 2007 at 9:43:28 AM
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:56 PM
Dimensions Disappearing
Tue, Nov 24, 2009 at 12:07:57 PM
Disappearing Callouts
Thu, Feb 14, 2008 at 11:36:27 AM
window frames disappearing
Thu, Aug 18, 2005 at 3:05:08 PM
Text Background Mask Disappearing in PDF's (Revit Architecture 2009)
Thu, Feb 12, 2009 at 1:29:29 PM
Page generation time: 1.1606
