Forums >> Revit Building >> Technical Support >> Invisible Masking Region outline
Tue, Nov 27, 2007 at 3:43:29 PM | Invisible Masking Region outline
Digitalistic1
I want to cover part of a detail component. I am using the mask region command. This works great however the outline still remains. Is there a way to erase or make the boundry of the masking region invisible so that one line remains? Or a simliar command out there? Thanks!
Tue, Nov 27, 2007 at 4:02:25 PM | Invisible Masking Region outline
aandr001
4.5 Stars: 6 Votes
Yes.  The masking region command is similar to the filled region command.  Select the masking region - click on the edit button - then select any of the lines or all of the lines and using the pull down menu in the upper left hand of your screen choose which ever linetype you want, invisible, hidden, fine...whatever.  They can all be invisible or they can all be of a different type.  It is very flexable.
Mon, Jul 11, 2016 at 8:30:05 PM | Invisible Masking Region outline
Luds
Luds Avatar
5 Stars: 2 Votes
@aandr001 This is invaluable help ! Thank you so much for this.
Tue, Jul 12, 2016 at 12:11:33 PM | Invisible Masking Region outline
aandr001
4.5 Stars: 6 Votes
Wow! It's not often that I am thanked for a 9 year old post!  But you're very welcome Luds.
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Masking region at section callout head.
Tue, Jul 30, 2013 at 1:43:26 PM
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Masking/Filled Region Does not work in Roof Plan
Thu, Jun 18, 2009 at 9:18:25 AM
3D CAD import Part and masking region
Sun, Sep 14, 2014 at 2:36:26 PM
Page generation time: 0.1458
